I have a Sony Xperia U and currently the firmware is 6.0.B.1.564.
And the PC companion shows that the new firmware 6.0.B.3.184 is available.
Can I directly update from 1.564 to 3.184 or do I need to update to the .162/171 first?
Also, if I do need to update to 162/171 first then where do I get it from?
Thanks,
robs246
thanks man.. updated to .184 .
The new firmware certainly is slightly smoother/faster..
Dont know what else was fixed but the UI improvement certainly helps..
Been using it for about 12 hours now and no issues so far.
Is there anyway to find out exactly what was a part of this upgrade?
thanks again.
