I'm from India. My Phone xperia pro (SI 1248-9084) and its there on the ICS list from sony. But still Im unable to update.
I have tried using PC companion as well as Update service using the link from sony moderator. Still gettimg message as "Your phone is up-to-date"!!
Any idea? Is it server issue? or do i need to change any settings?
If its a server issue?
Do I need to regularly check using PC companion or Update service for it
the servers are overloaded just be patient
Don't forget to mark theCorrect Answers & Helpful Answers
Thanks for you quick reply...:smileyhappy:
But u didn't answer my last question... Okay i wil repeat it..
Do i need to check my "PC companion" or "Update service" for the ICS update?
Which one is the best and fast?
Thank you once again!!!
yes you do, SUS is the best way to go
smae problem ..been trying for the past 3 hrs
Same problem! My SI is 1248-6159, I've been trying for the last 24 hours and no update available...
All my friends from India
I just spoke to Sony xperia support India 180030002800
The have confrimed that the update is not available .. It will take a week for it to be available..
I dont understand why they have put it up on the list
nilay seems right since I am also trying to update my xperia pro ti ICS for a week but everytime it shows an error sayig unable to install or update phone software components... Also my SI is 1248-6159 and its vry much thr in the list too....
My SI no. is also in the list with release date of 21st June. But the PC Companion says that my phone is up to date. When the support center was informed, they told that the update is not available at this moment, it will be released by the end of this month. Why this confusion is there?
Servers overloaded?! I have been waiting for this update from a long time and patiently waited for my SI number to be added to the list. My SI number is on the list but PCC or SUS doesn't show any update. I'm sure that Sony has got pretty fair idea about the load on their servers and their servers can handle the load.
Would expect reply from some support team members on this one. In spite of our SI numbers being on the list, why aren't we able to update our phones? If overloaded servers is the problem, when will the problem be fixed?
