Hi guys since I upgrade to ICS does not work TrackID. when trying to start it I have a mistake ...
any solution? I need help...
Thanks
Greetings from Colombia!!!
okay. I am resigned.
one last thing as I can do to root ics 4.0.4 ?
My bootloader is closed again.
did you unlocked the bootloader or just rooted the phone?
check this out
http://talk.sonymobile.com/thread/38251
Ha ha, great job man... Couldn't have said it better. :smileyplus:1 :smileygrin:
Both and in fact it happens to me exactly the same thing with the error notification... Why?
even w/ a unlocked bootloader? it won't work
if you unlocked the bootloader it will never work
Hey... I know it was years ago but.... I discovered a way to fix that problem and get the stock Track ID and the facebook like working with any problems.... well it is in spanish but maybe it can help somebody as it helped me..... here's the link http://www.htcmania.com/showthread.php?p=12364743 try to do it!! it worked with my bootloader unlocked!!
