TrackID error 5 ICS 4.1.B.0.431
Hi guys since I upgrade to ICS does not work TrackID.  when  trying to start it  I have a mistake ...
any solution? I need help...
Thanks
Greetings from Colombia!!!
there you have it, that's the reason its not working and it won't work at all, your DRM files are forever gone, no you can't reinstall them.
17 REPLIES 17
Same over here... But I actually kind of fix it. I just installed the track id apk from the Xperia S and now I have 2 track id icons Smiling_Face_with_open_mouth_&_closed_Eyes and obviously just one actually working... I hope it helps. Look for it, there are plenty of packages around with many Xperia S goodies (not all of them work)
did you unlocked your bootloader?. do you have a data plan or wifi connection?
are you talking about this?
http://talk.sonymobile.com/message/213926
Yup, that's one of the packages. I just extracted the apk and istalled it :smileygrin:
yeah i modify the bootloader but i closed but again, I have wifi and 3G connection
ok thanks. But you are absolutely sure there is no solution That? and the bootloader is closed again.
there isn't the XDA developers already tried to do this, and you can even read it at the Sony bootunloader unlock site that they are gone forever
I uploaded a wrong pic before... he can't recover the files already lost but can install the Xperia S apk an it'll work fine I got my Pro rooted and it works.
