third party earphone doesn't work on 4.3 update on Xperia tx
shay131
I was able to use any third party earphones (my apple earphones) to listen to music on 4.1, but after updating to 4.3, my Xperia tx does not detect my earphones!
Phone: Xperia tx lt29i
Android version: 4.3
Tags (2)
profile.country.RO.title
_alexdon_
It could be just incompatibility after the update.If you contact xperia care,they will tell you to use only sony earphones.
alexdon
12 REPLIES 12
_alexdon_
Try to clear data for smart connect in settings-apps-all.
alexdon
shay131
Just tried. Unfortunately it doesn't work. Thanks
_alexdon_
alexdon
shay131
Thanks. It's quite annoying. I can't find a walk around either
_alexdon_
Anytime.
alexdon
Thommo
Genius
There is but it's complicated - It involves rooting and altering the headphone code which most have if they have volume control and the ability to answer calls etc
shay131
Seems difficult
Thommo
Genius
For your consideration here - Tested on Z ultra but it is claimed the procedure will work on other models
shay131
Thanks. I'll surely give it a try and keep you posted
