Xperia S LT26i showing up as Media device in device manager
Knight190
Hello everyone,
i have a Sony Xperia S LT26i, version 4.1.2 build 6.2.B.0.200. I was trying to install the ADB drivers for it for the past few hours, tried many different files, re booted my phone a lot of times, rolled back drivers and re-installed them but to no avail. I also used the android SDK and installed the Google usb drivers and the other necessary drivers but nothing happened. The mobile is listed under portable devices as Xperia S, was previously listed as an MTP device and now as a WPD composite device ( I don't know what the **bleep** that is). Please advise, literally at my wit's end and don't know what to do :smileycry:...
Thommo
Genius
What is it you are trying to do?
Have you tried turning on or off USB debugging in Developer options on your phones settings and you may also need to uninstall PCC and the driver via device manager then reinstalling PCC
4 REPLIES 4
Thommo
Genius
Knight190
Hello,
I will try uninstalling and reinstalling the PCC and the drivers, thank you for the suggestion. I was trying to get root access for my mobile to play games and install apps like chainfire lol. Thank you so much for the reply, have a good day.
Regards,
Usman
Thommo
Genius
Well the easiest way to get root these days is via DooMLoRD Easy Rooting Toolkit
Scroll down and look for this
PLEASE DO NOT MIRROR MY FILES!
NEW:
DooMLoRD_Easy-Rooting-Toolkit_v17_perf-event-exploit.zip
Once downloaded follow these instructions
  1. just download the file, extract it completely using winzip/winrar
  2. go to the folder where its extracted and execute "RUNME.bat"
  3. read and follow the instructions on the screen!
  4. REBOOT THE DEVICE AFTER THE SCRIPT HAS FINISHED EXECUTION!
Just to add for anyone else reading this - There is now no need to unlock your bootloader this will work on both locked and unlocked bootloaders
PlayPratz
Hello There!
I am having the same exact problem! Please help me! I have tried reinstalling PCC but no luck 😞
