Hello guys.. I have sony xperia acro s
Andriod version : 4.1.2
i put it in charger around 4 hours and still showing only 1% of battery
i try different charger still same problem.... any help please ...
I restore it and tried many chargers help me please
Try a force restart(power button+vol up until the phone vibrates).Do you see a different battery percentage?
now its showing 28% ...thanks bro ... will it show it again ?
It was probably a glitch,hope not.Connect to wall charger and fully charge your phone.
thanks ...you are the best ^_^ sorry to bother u .. last quiston ... is it a big problem ?
No,like I told you,I think it was temporary.However,if you encounter any problems again,come and tell us here.
I'm having the same problem. Recently it started showing either 1% or 100% constantly, nothing in between.
I just tried forcing a restart, and it switch to 100%. So I tried it again, and it's at 1% now again.
I'll try the advice listed here:
And then report back.
If there's any other ideas I can try, I'd be up for that too.
Thanks
Sure,report and we will suggest something else if that does not help.
Alright, I tried `Update_Service_Setup-2.11.12.5.exe` but it seemed to do the same thing as the PC Companion (which I had already installed.
So I went back to just trying that.
It recommended I perform a backup, but the backup kept failing. Perhaps because my device is rooted?
Most of my data is synced via Google, so I can recover most, but I still wanted a backup incase.
Since the Backup isn't working, I'm using Titanium backup, and once it completes I'll go through the repair.
Re-applying root isn't quite ideal though, and this is getting to be a hassle. Again I'd appreciate other ideas that might help.
Giving that your phone is rooted,I cannot give you much support as I am not informed about it.The thing I would have suggested was the software repair,which will remove the root.
