System problem
sonyxperiajowne
System problem
hellow friends.
i installed Chainfire3D
https://play.google.com/store/apps/details?id=eu.chainfire.cf3d
and system spoils
When i press inclusion of button
"SONY" Logo Stays and do not turn on properly
Sorry for my bad english
Thommo
Genius
Best place to find these files are XDA here and look for the stock roms or to relock your bootloader try this here You can Google Flashtool instructions but a good guide is here - Ignore the title as it's the process you need to follow
6 REPLIES 6
Thommo
Genius
Did you install it to a rooted device if not then theres your problem - Your only option now is to perform a system repair using either PCC or SUS found here - For PCC fully switch your phone off then Select Support zone then Update my phone/tablet then in blue select repair my phone/tablet and follow the instructions remember when promted to hold volume down and connect your usb cable - Do not attempt to power on your phone during this time or at any time leading up to connecting it
sonyxperiajowne
buy my deivce can't finishes starting and it is problem(and my computer can't detect my device)
my Device About:
Sony Xperia J
Relock Bootloader
Rooted(but now I don't know)
If you want,I'll Record video
Sorry for my english
Thommo
Genius
In that case you need to manually Flash a relock bootloader file then use PCC or SUS or download a stock .ftf file and manually flash using Flashtools
sonyxperiajowne
ok and where can i find this file?
Thommo
Genius
sonyxperiajowne
it worked.
Very much tnx.:)))
