Switching keyboard to type another language
mokevinmo
I wonder how to switch to another keyboard when im typing.
Before acro s, I was using experia arc, its just simply hold the typing box for a few seconds and then I can swith to another keyboard typing another language, but it doesnt work for acro s. Anyone can help me?
zhuhang
For acro S, u can't change language from keyboard. (If im not wrong)
Simply pull down your notification bar, and there's a change language setting. (Only shown when keyboard is activated)
Or go to language/input settings and select different keyboard as default.
3 REPLIES 3
zhuhang
mokevinmo
Thanks!
tomstor82
It is possible to switch between keyboard languages while you're typing on the Acro S. I set up my keyboard in settings, language & input, and then settings for the Xperia keyboard; for two languages, and a button appears on the right side of "space" which displays "EN" or "NO" for my english and norwegian setup.
