Specifying "Proxy" settings on WiFi.
Izual_Rebirth
Morning all,
I use my phone at work and can connect to the office WiFi however to gain access to the internet I need to put in a proxy server. On my previous Android phone there was an option to specify a "Proxy" server however I am unable to find it on my new Xperia P.
Would someone be kind enough to point me in the correct direction for where I can put in these Proxy settings so I can connect to the internet at work. I am unable to use Data Traffic as the signal in this area is quite poor.
Thank you in advance,
profile.country.RO.title
_alexdon_
you can add proxy server,actually you can set proxy for a specific network.go to wifi-go to  the network-tap longer on it-modify network and go down down until you see show advanced options.there you get the proxy and port fields.it should work.
alexdon
7 REPLIES 7
profile.country.PH.title
MarlonUk1
you may need to download apps on google play to be able to use proxy.
Izual_Rebirth
The only apps I can see on Google Play require my phone to be rooted. Is there no way to do this through the OS?
MarlonUk1
unfortunately the stock OS does not support this feature, Slightly_frowning_Face how about searching browsers that support proxy?
Izual_Rebirth
It's strange because my last Android phone has Proxy support. I don't understand why Sony would remove it.
_alexdon_
alexdon
Izual_Rebirth
Thank you so much. That answered my question and now I have internet at work.
You are amazing Slightly_smiling_Face
_alexdon_
You are welcome,my friend.
alexdon
