How can I sort my contacts by family name ? By default they come by first name. As explained in the tutorial, I tried through menu -> filter but then the option "filter by list" or something like that doesn't show up... What's wrong ?
You should be able to set this by following these steps if you are running on Android 4.0:
Contacts > Menu key > Filter > Sort List by > Last name.
If your handset is running on Android 2.3.4, this option would not be available.
Hope this helps
What do you think about this forum? Let us know by doing this short survey
Hope this helps
Thanks ! Great help. Mine is running on Android 2.3.4, so too bad for that
