Sony release a new version of TrackID 3.60.39
How to update? The discussions that if you read it downloads and installs it in the phone are two applications (old and new).
Original remove and install new or is there another procedure?
Thx u.
There is one more small issue, which i also posted on https://www.facebook.com/sonymobilein but didnt got any reply from there.
I have Neo V. I bought it in December 2011. First when i used to Update Status from Timescape, it used to show Sony Ericsson Logo on Facebook. I have latest software update on my cell.
After Sony Ericsson Mobile became Sony Mobile, Logo is changed. But it doesn't show when i Update Status now through Timescape, also when Xperia Link (which is shown below status) is clicked then it show "The page you requested was not found."
Will it be fixed in next update ? And when is Sony releasing ICS update ? Is the date decided ?
Thanks in advance
Thanks in advance,
Sushant N. Kiri
I've the same problem,my track id tell me i need an upgra,but it doeasn't work !
Same here.
Weird that it's 7th of April, this issue is a month old now. Probably hard to solve for Sony guys.
zimpee
Any news about TrackID problem solving?
The issue is escalated and there's a team working on it as we speak. Not sure what the current status is though.
OK people, this should be solved now. Can you please confirm this?
To shed some light on the problem and what's been done to fix it:
When the first recognition is done in TrackID the application checks if there is an update available on the “Java update server”. If there is no update, the client should get an empty body in the response. The Java update server was recently moved and with the move a small change was introduced: Instead of an empty body, the server responded with the text “Latest version is used” or something similar. This small text body from the server response was interpreted as an update package by the client. Consequently the update failed.
Now the implementation is changed so no text body is included in the update response.
