I've updated the software version to 4.0.2.A.0.62 and since them when i'm making a call everytime i press the lock/unlock button the phone shuts the call.
Before the update it didn't happen. I used to lock the keyboard when i was making a call and now i can't do so... Is it normal? Can i turn any option on/off?...
try this
go to settings > accessibility > unmark power button end call
check if it is marked
Hi, just curious to know, why do you need to lock the keyboard when making call? The proximity sensor will do the job by disabling the touch screen.
Lock/unlock button - On/Off button?
I think it is absolutely normal, maybe you have to adapt to this change.
It was marked yes... But the update shouldn't mark this...
I just didn't know where to search for this option...
Thanks
At least for me the sensor isn't making his work very well...
Sometimes my hear press the top right corner and it turns off the mic...
thats what striking my mind again and again
why would update mark this itself :smileymischief:
Don't forget to mark the Correct Answers and Helpful Answers
I see ....
I've tried the service, *#*#7378423#*#*, and the switch turns on when i move my finger over it
This is a known issue on LWW, when talking, the proximity sensor will turn on the screen with any small movement of your head, and on the next step your ear will activate the mic mute or end the call right the way, and also reported it will turn on the speaker, it happens to me on 100 % of the calls, the way to avoid that is to lock the screen by pressing the on/off button. That is very annoying, I'm returning my phone to the store, I consider this to be very elementar on a phone design, and I don't want to live with that.
