Software Update Issue
Ok , I am having this problem . My device is Live with Walkman , i unlocked my bootloader and rooted my phone , i was on build number 0.62 , unfortunately i messed up something during the flashing of a custom ROM.. so i had to flash the official SE Kernel with build number 0.42 . I relocked my phone's bootloader successfully then UnRooted and ran the repair PC Companion but it gave me an error . Now I don't know if I can fix it somehow because I want to update my software back to 0.62 or i should flash the official 0.62 kernel..
Nabeel
What error did it show ?
Redo the whole process again
or use
SUS ( Sony Update Service)  ... download and install it on pc and follow the on-screen instructions http://www-support-downloads.sonymobile.com/Software%20Downloads/Update_Service_Setup-2.11.12.5.exe
                  or
Both the links are same
5 REPLIES 5
Nabeel
or use
                  or
try this
Live w/ Walkman WT19i 2.3.4 Build number 4.0.2.A.0.62
http://talk.sonyericsson.com/thread/30983
and also you might want to relock your bootloader
this is how
http://forum.xda-developers.com/showthread.php?t=1324703
As I mentioned in my original post , I already relocked my bootloader , I am going to try the SUS method .
Incredibly helpful ^^ thanks a million .. everything is back to normal
