Rooting for Xperia Arc S - Android 4.0.3
i want to root with this way: http://forum.xda-developers.com/showthread.php?t=1601038
If something goes wrong, can i repair my phone using Sony Update Service or Flashtool? And is the System exactly as performant as before? Or is the performance not as good as unrooted. How high is the performance ""Speed" after removing Bloatware? is it much faster? THX
Nabeel
{GUIDE} How to Root Xperia™ Smartphones
Remember ROOTING may void your warranty and you are doing it at your own risk
Yes you can use Sus or PCC anytime ( even flashtool )
system gets exactly the same
after you remove bloatware , you free up a lot of ram and internal memory which results in faster speeds and hence performance Slightly_smiling_Face
3 REPLIES 3
Nabeel
can you give a link for the screenshot, which apps i can remove?
Nabeel
here is the list of apps that you could remove
http://forum.xda-developers.com/showthread.php?t=1614761
