SMSawake not working.
dilm
I'm using the 4.1.B.0.587 update from Sony but it still hasn't fixed the SMS LED issue so i installed SMSawake on my ray as suggested by most users here. My problem is after installing the app on my ray, it didn't work. I'm using Go SMS Pro as my default messaging app. I tried reinstalling the app then restarting the phone but it still didn't work. I hope someone can help me with this problem. Thanks! :smileygrin:
Veresova
1. after installation, you set the minimum time 2s?
2. maybe that SmsAwake working with another application than the default.
6 REPLIES 6
Veresova
dilm
nope. I used the standard 5 sec in the settings.
dilm
Ok. I was able to fix it. There was another app blocking the function. Tnx Veresova! :smileygrin:
Veresova
It is good news Slightly_smiling_Face
mvrk80
Dilm wich application was blocking the function? I have the same problem with my ray. SMSAwake doesn't fix the sms notification led issue
Ty for your answer
mvrk80
I hate this fix only sms! The final solution is here guys:
http://talk.sonymobile.com/thread/51425?tstart=0
