When I place my Sola display up, the main speaker which is on the rear side becomes so silent so that I quite often miss incoming calls. Is there any solution to this? Is it possible to enable the ear speaker for incoming calls ringing or is there any other way to make the phone loud enough (except for placing it display down)? Thanks for any help.
this is a hardware/design issue, it can't be solved, the only options are
1) face down
2) sideways (on a cradle or dock)
3) partially lift one side of the phone (top or bottom)
