I dropped my mini :smileysad::smileycry::smileycry::smileycry: the glass is broken, but i still can use the phone, what can i do to get it repair???? how do i know that i have warranty or not on it? Does the warranty cover the glass?? what is the difference between the authorized sony repair shop and the repiar shop? pls help!!!
check this out
http://www.ifixit.com/Teardown/Sony-Ericsson-Xperia-Mini-Pro-SK17i-Teardown/7275/1
thank you, i check this out and try
let us know how it goes
sure
i let you know
how did it go?
we are ordering the broken part just now.
is any difference in the hardware between sk 17a and sk17i? And one of the videos says that the glass and the lcd can be separeted, the other videos says that they are glued together... which one is right?
SK17i it's the same as the SK17a the only difference is the 3G frequencies they work, you can use either or software/firmware w/o affecting anything at all, as the 3G frequencies its based on its antenna not software
thank you:smileyhappy: and should i order just the glass or the glass with the lcd?
if the glass/digitizer it's cracked get that, if the LCD it's not working get both
