Is there any option to set particular number as primary in the Contacts list.
Example : Contact A has two number
mobile number1 : 1211111
mobile number2 : 8121212 (can set this number as primary) to make a call.
If Option has not been provided by SE.
Can you suggest any android apps to achieve this functionality.
Hi, I believe this is what you are looking for.
Launch Contacts app, longpress that particular contact, select 'Edit number before call'. Mark 'Remember this selection', then tap on the number you want to set as default.
