questions/problems with 4.1.B.0.587 firmware
linainvers
a couple of problems that I have after upgrading to the new firmware.
1. After the upgrade was to lose the network, literally 10-20 seconds
2. Аfter a reboot resets the network mode (where you can select the network mode only 2G, Mixed 3G/2G).
3. in the new firmware added swap partition in the internal memory, it will not kill her (internal flash memory)?
linainvers
in the new firmware sony added swap (pagefile) partition 60mb ( zram0 ) in the internal memory.
Flash memory have a limited cycles of write/erase.
and how it affects the life of the internal memory ?
4 REPLIES 4
Johan
I haven't noticed your first point as something common for this update. Please share more details about this.
2. This has been forwarded yesterday.
3. I'm not sure I fully understand what you're thinking of here. Please elaborate this as well.
linainvers
linainvers
and ?
claumr
hello,
i have the same firmware(4.1.B.0.587) on xperia arc and I notice that the camera has poor quality same to camera video than when i had gingerbread ; and when I play games(asphalt5/hawx/realF2011etc) crashes every time. Beside these inconvenients pr it's ok, and i don't want to go back to gingerbread, i hope for a new update to solve this problems
