Question about headphones setup and sound related.
m4dj
Hi ! I have 2 questions. Today I have connected my earphones to thephone. When connected, the phone ask if I want to choose the application so that will launch automaticaly when connecting headphones. Ok I have try it and choose winamp. It works but now I cant find the way to disable this feature.
Everytime when connecting the headphones the winamp starts. I checked every menu but did not find any option to disable it. Anyone ?
Second one:
The other thing I have tested : I have played some music on winamp and recorder a video with music enabled. Then I listened to a recorded video with earphones and it seems that only the left ear part is working. This indicates that the recorded video is not sterao if I am not wrong. I also tried to record a video in a normal way without winamp enabled , but the results in playback are the same.
Its interesting that if I record only the sound with hi-q mp3 recorder, I get a stereo sound and both sides of earphones works.
Thats strange.
gwhispererz
1st answer: Lauch Liveware manager, select Headphones (my guess)>Assign and search, either select none or another option. Same method for other options in Liveware manager.
2nd answer: Actually not an answer, just a test .... test with other video recording or downloaded video, see if you are getting the same result.
3 REPLIES 3
gwhispererz
m4dj
Thank you ! I forgot to check this application because I have never use it. Now the first one is solved Slightly_smiling_Face
On second one I will try to test it. Regards
I have just tedted one more time. I record my own voice and video using the built in recorder. It working ok on earphones and both sides works.
I have also tested the playback of the movie in other application using "quickpic" app. It works.  Maybe it was just a case.....
Also tested a recording with winamp playing in background...and it works.
gwhispererz
Great!
Keep us updated on the test.
