i know this issue was reported by neo v users.. but day before yesterday i faced the same issue ,
yes , with flash light on..
its the first time i saw this.. and probably the first time i used flash in low daylight , i'll take more pics and see if i get same issue...
see some pics here,, i took them today for u
1..fringe occured due to sunlight
TO AVOID FRINGE I CHANGED THE ANGLE, AND IT DIDN'T OCCUR HERE -
CHECK OUT THE OFFICIAL VIDEO FROM SONY... IT HAS PURPLE FRINGE TOO
SEE FROM 2:27 onwards
slim , smile ,coz ur camera is all fine
u don't need to worry
explanation for this pic : camera lens is purple in colour... when light is directly incident on it, from some extreme angles, not all but some extreme angles it gives a purple shade, here in this case, on the ceiling there is an electric bulb, so this purple fringe just occured in the area where light from bulb was incident on lens
u can check this,,
i took a pic in day light, in which fringe occured when flash was off...
so this is not a defect
chill
and i hope u feel relaxed after reading this
:smileygrin: yes i feel relaxed and i did not know this... great
yes there are purple fringes
great....
but there are many people with neo v having the same trouble
reply there also..
neo v has camera defect...
fringe occurs everytime when flash is used
so sadly we can't help them
so after few thinking i decided to open the mobile.flash isn't fully protected around it so when it glows flash reaches camera and creates this.led goes in a clean circle vesel.i putted black tape around it and that's it i can use flash at last.btw gz erricson engineers....:smileyangry:
