Problem with Facebook inside Xperia
I have this problems for the last 2/3 days.
Could you help me out?
I have just installed the newest update just now, but the problem exist.
Heres the screen shot.
slimshaddy
Hero
ok
update your phone with this..
http://dl-www.sonyericsson.com/cws/download/1/110/61/1309763183/Update_Service_Setup-2.11.7.13.exe
this is an official sony software so don't worry..
and if it says your phone is up-to-date click on install anyway..
this will delete all the phone's data so backup all your files first..
how to backup..!!
download any one of the file on your computer . ( if you download this directly on your phone , it will be easy , if not then download on your computer )
http://www.mediafire.com/?78bcyp5alpwy0ok
after downloading it , follow these steps
http://talk.sonyericsson.com/message/130376#130376 from step 2 onwards..
9 REPLIES 9
slimshaddy
Hero
go to settings > applications > storage use
find facebook , open it and select clear data and uninstall updates..
Yes slimshaddy,
done that... But still the problem persist.
slimshaddy
Hero
strange...
go to settings > accounts and sync and turn off auto updates...
also go to settings > sony ericsson > facebook inside xperia > disable it..
open facebook.. press the menu button and press log out..
re-start your phone..
then try to log in..
done that,,,
but the problem still exist!
Its really annoying me now.. Slightly_frowning_Face Grrr....
slimshaddy
Hero
ok
how to backup..!!
ok sure will do...
Thanks..
will keep it up to date.. and hope it works...
Oh... it say X10_SE ,,, does it also works with Xperia Mini Pro????
Johan
Keep us updated if the problem remains after update.
The update programs are the same for mini pro as for the X10.
Thanks Slimshaddy / Johan
I finally updated with the SE programs, and now its fine.
BUT, after installation i notice the same problem again, and after installing my apss, this and that, and restore my backup.. restarted it and it work????
Still don't know the reason, but its fine now..
Thanks again
Rony
slimshaddy
Hero
great Slightly_smiling_Face
