I have updated my Xperia P to latest Jelly bean but the pictures in the Album does not appear. I have repaired the system also still the same issue occears. Only the blank screen occers when i click on album icon.
Please suggest me on this issue. What needs to be done for this.
settings > apps > all > album> clear everything > restart your phone > check again
Follow uliwoolys advice.If not working,try to use one of the photos from album as background,try after to look again in album.
why are you creating new threads on the same topic?
https://www.box.com/s/ep07u7g1gp0d4w2g44fs install this apk and check if ur problem is solved
As it is not the issue with Album now.. when ever the phone is ib standby mode for more than 2 to 3 hours then when i unlock it then it goes to network unavailable. And also the same issue occers oftenly when i an browsing or working on the phone.
Please provide the solution on this problem.
try changing ur sim to a new one ...
this a moded app for album (only xperia p) .. many reporting the album issues aft jb upgrade .. so xda developers had done this app to resolve the issue ..
Please let SONY does the new update does not work because my album and I'm pretty pissed off. PLEASE It is the only fault to me JELLY BEAN.
