Powerbank question.
fedebt
Powerbank question.
Spoiler
Hy all,
I have a question about using Powerbank external battery for my SP.
I have a Powerbank with 2200mAh and I can charge everything with it, like an iphone4, my digital camera, I tried also with a HTC Wildfire, a Samsung S4, a Samsung Wave II but not my SP.
So i can say for sure that it's not a Powerbank issue.
Has anyone the same problem?Or someone can tell me something about?
PS: i also tried with several USB cable but nothing.
fedebt
Tags (1)
fedebt
IT WORKS!!
awsome!!
So my previous powerbank, the one 2200mAh can charge a Samsung S4 from the bottom but not my Xperia SP.
My new one 10000mAh work like a charm and fast with 1A output!!!
what a relief to know that i do not spend my money for nothing!!! :smileywhew:
So it was my previous powerbank problem....weird but true....
21 REPLIES 21
Thommo
Genius
Whats the amps on it? if they are low then your phone may not detect it
fedebt
Hy Thommo,
2200mAh.
Even an S4 gets charged...like i said before i don't think it's a powerbank problem.
my SP gets charged well will wall socket charger or via USB, this is he weirderst thing,
via USB the phone gets only 500mAh and no problem!
Thommo
Genius
Thats the size of the battery but it will have a 5v x amount of Amps output
Example check your wall charger it will say 5v 850mA
fedebt
Specifications are this for powerbank:
capacity : 2200mAh
Input : DC5V - 1A
Output : 5V - 1A
For wall socket i use original Sony and it's like you said 5v 850mA
fedebt
it's not a real problem, i just want to know if there are limitation or else for powerbank.
Thommo
Genius
The V and A are fine so should work - Does your phone charge if connected to as Pc? Strange why it wouldn't work - There's no signal which says reject the charge if not using a genuine charger unless the powerbank is refusing to charge your phone - Wonder if there's a compatibility issue - Maybe ask the makers of the powerbank
fedebt
yes if connected to a PC it charges.
Yes it's really weird. Anguished_Face
i'll do some other research, if i'll find something i'll post here
thank anyway Thommo
Danial-mach1
Leader
that cable which you charge your phone comes with your power bank??or you use your sp orginal cable?
fedebt
Hy Danial,
tried with both.No way.
Any cable i tried with other phone or digital camera or even my wireless mouse works!
Reaaaaaally weird!:smileycry:
Not a big issue, but...what the f.....!!!
