a few weeks ago I was on the phone whilst in the bath soon after (when i was out of the bath) the home button went blue and then the phone completely turned off. When i went to turn it back on it done nothing it doesn't even turn on, nothing happens when i put the charger in either.
The before this happened I pulled off what looked like a screen protecter on the screen, altough it was much thicker then what you average protecter is like.
When I plug the phone into my computer it can be found, but when i try to turn it one NOTHING happens not even a vibrate nor does anything happen when i try to charge the phone.
Please help I love my little ray and really want it to be ok:(
See if it helps
Update/Repair your phone via PCC OR SUS
SUS ( Sony Update Service) ... download and install it on pc and follow the on-screen instructions http://www-support-downloads.sonymobile.com/Software%20Downloads/Update_Service_Setup-2.11.12.5.exe
or
Both the links are same
See if it helps
or
