Phone memory shortage
Hello, i've got a little problem with the new .62 update. I've own this phone since October last year and was not giving me any problem until Sony Ericsson Sync Shutdown
1) Facebook : I dont know why but now my facebook friends contact picture WILL NOT sync. As in it will never update their profile picture but their statuses will. Having this problem since begining of the year.
2) Internal Memory : Having the problem the above,I erased all the memory from my phone. EVERYTHING in fact which includes dozens of apps that are installed into the phone and also internally. But just installing one app and then i've got a warning said my internal memory is almost full ( 30MB left ).
Im surprised cause there is not enough space but then i deleted everything. Before this i usually have at least 60+ Mb free space and can install Whatsapp / Line / FB messenger and G+ all into the internal memory. Now all these apps i have to install into SD card.
why don't you backup and then repair it with Update Service
Update Service (SEUS)
http://dl-www.sonyericsson.com/cws/download/1/110/61/1309763183/Update_Service_Setup-2.11.7.13.exe
Make sure you backup everything
Settings -> privacy -> Back up my data and Automatic restore should be selected
and also
Use one of these links to download the
Backup & Restore app
or
http://www.elita-clan.com/downloads/backup_and_restore_v010935.apk
http://www.elita-clan.com/downloads/backup_and_restore_v010935.apkor
How to install it
You need to
download IO File Manager
download the backup & restore app, transfer it to your SD card, use OI file manager to find it -> tap on it -> install it
Contacts
open your phonebook
on your computer
Apps
Don't worry so much about backing up your apps
on your computer go to
market.android.com -> log in -> click on My Library -> and send all your apps to your phone
market my library.JPGmarket my library 02.JPGmarket my library 03.JPGmarket my library 04.JPG
SMS/MMS
if you don't want to use the backup & restore app then
Install "backup SMS" to back up your SMS and MMS to your Gmail
or your SMS use
"backup & restore SMS"
or for your MMS use "Save MMS"
Call Logs
And for call logs this is great
8 REPLIES 8
and also
or
How to install it
You need to
Contacts
open your phonebook
on your computer
Apps
SMS/MMS
or your SMS use
Call Logs
this are methods on how to side load apps
1st Method
How to install it
You need to
download the app on your computer, transfer it to your SD card, use OI file manager to find it -> tap on it -> install it
2nd method
download the apk on your computer, send it to yourself through email, make sure you send it to your Gmail
now on your phone
wait for the email, once  you get the email, open it, and instead of downloading the attachment it will allow you to install it, voila, done
3rd Method
BOX and upload the apks from any computer
install the App on your phone -> open BOX -> tap on the app -> install it
4th Method by far the easiest
an even Easier alternative
download the app, transfer it to your SD card
Download Apk Manager
https://market.android.com/details?id=com.magmamobile.app.apkinstaller&hl=en
open "Apk Manager" and voila select the apps that you wan't to install
if you want to increase your internal space this is how
http://talk.sonyericsson.com/message/151131#151131
WOoooaaaaah dude, thanks for the Step by Step guide on repairing it...will try it now and will leave a reply soon...BTW when i took out my Memory Card and check the Internal memory, It has over 200MB + free space...do you know why is tat?
theres probably an appp acting up
Well repairing it really works. Thank You VERY much dude !! :smileygrin:
Anytime
Italiano
I do have some problems with my J Xperia! I lost conctact number + troubleshotting + not good coverage! Can anyone HELP? THANKS MR Mauro Zampedri
