Hi there , I tried to do an software update this morning with pc companion , when it's updating half way it came up with an error . then my phone switched off . now i tried to switch it on , it shows a triangle with yellow exclimation mark next to a phone . the pc won't pick it up when I connect usb . what must I do ?
________________________________________________________________
SUS ( Sony Update Service) ... download and install it on pc and follow the on-screen instructions http://www-support-downloads.sonymobile.com/Software%20Downloads/Update_Service_Setup-2.11.12.5.exe
or
Both the links are same
Try downloading SUS [Sony Update Service] google it...
Then install and choose upgrade/repair, I think that is the official way to do it.
Good luck.
you reckon its going to work ?
Should do, I haven't personally repaired the phone with damaged software [which is what you have, half an install on your phone] so it should "flash" the phone with new software.
Try and it report back, I'm 80% certain it will work for you.
or
