My X8 hangs after Android update
Hi since adding ndroid 2.1 through the official support site my X8 hangs about half the time when making calls. Specificaly the display goes out and you cannot end the call. The call does go on but to hang up you need to remove the battery. WiFi is runnig nOK and its OK on texts, only phone calls.
Any ideas?
Thanks John
15 REPLIES 15
OK tried update, and still the same. Call starts and display flashes then goes blank and no more control.
ok, that was fast, you have 2 options
1) manually flash the other android version and see if this solves the issue if not then
or
2) send it to Sony Ericsson repair center
http://www.sonyericsson.com/cws/common/contact?cc=gb&lc=en
and you are certain that there isn't anything covering the proximity sensor? do you know where its located?
Hi where is the proximity sensor so  I can check it
The proximity sensor
http://dl-www.sonyericsson.com/cws/download/1/835/748/1284993031/E15i__UG_EN_ROW_1241-4245_1.pdf
Double check for dust, trash, etc that might be covering it
Thanks you are a star. gave it a clean and it works now. In test mode you can see it moving from off to on now. I gave it a good clean with a lens cleaning cloth as just rubbing it made no difference.
that makes me look like a right muppet. But the phone works now Slightly_smiling_Face
Anytime, I'm glad it works now Slightly_smiling_Face
