- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
My Sony Ericsson Xperia Arc S (LT18i) keep on restarting itself ( reboot loop )
Dear Support,
Kindly be informed that My Telephone keep on restarting and don't know how to fix it, i try several solutions, but it didn't work until now.
i try to work on PC compinion, but it can't detect the mobile, becasue it restart.
i try flash tool ( EMma) but it can't detect the mobile too.
i try to use hard reset & safe mood ( Power button + Volume down) & ( Power button + Home & Menue) but nothing happened.
would you please advsie how to fix it, it's urgent to know this solution, because i need it
Note: i don't need the data on the mobile, i need the mobile to work.
Best Regards,
Hisham Abd EL Hamied
E-Mail:
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Try removing youer SIM card and see if this makes a difference as a faulty or worn SIM will do this however if this fails to make a difference then you need to either return your device to the place of purchase or contact Xperia care and have your device inspected http://www.sonymobile.com/global-en/support/contact-us/
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Thanks Thommo, Kindly i removed SIM Card & SD Memory too, any advise how we could solve it.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Try performing a system repair - This will factory reset your phone
Start PC Companion and select Support zone then Update my phone/tablet then in Blue Repair my phone/tablet and follow the onscreen instructions - When prompted connect your phone still switched off holding volume down or back button - This should start the repair or reformat process
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Kindly i did that and it said that pc companion try to detect it but after a while, it said pc companion couldn't detect it
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Check device manager and see if the driver is installed when you connect via holding volume down and connecting your usb cable whilst the phone is switched off
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
hi...
i have same problem here ...and pcc is not detecting my device...plz give me solution...
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
same problem
no code is working
also cant connect with USB
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I am also unable to Instal the same thing Even my Mobile is automatically Restart
Please Help me out.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Just turn OFF bluetooth... and then it will be OK
But you must be quick
