MTP & MSC problems
Focuscar
MTP & MSC problems
Hi, I have Xperia Neo. My problem:
OK
- I connect to PC in MTP : copy/move any file, unplug phone everything is fine.
Problems
- I connect to PC in MSC : I move different types of files to another location in sdcard itself. Unplug device.
I open my File Manager, and it successfully shows that everything was correctly moved in my sdcard.
I open my Xperia Gallery, BUT it still shows all 'moved pictures' in their orginal location , PLUS they are all dumb files.
SO
I connect back in PC, still in MSC : all previously moved files are correctly in place
I switch to MTP & connect to PC : all previously moved files are still in original location AND are all dumb files. (The good ones cannot be found anywhere)
Switching 100times between MTP & MSC does not change anything.
- It's like 2 different drives on the same sdcard.
- Xperia Gallery using the MTP drive
- File Manager using the MSC drive
Question
So now, wth is all that? Is it a normal behaviour? if so does it not render MSC completely useless if the Phone (Xperia Gallery) seems to use only MTP?
Please Help. -.-"
Focuscar
Formatting my microSD card directly into my PC resolved my problem.
Focuscar
