Lost space
Danial-mach1
Leader
Lost space
i have 400mg lost space on my internall storage
for example if phone shows 1gb free space when i connect to pc it shoes 600mg free space
i cant find anything that cause this diffrence...no hidden thing..no system protected or system hidden thing
any idea??
3xperia
@ Danial
There's nothing wrong with that at all. Stored chace or some space that should be empty for the system.
Take a look the visible difference clearly
Your PC reads 768 MB of 5.37 GB of the internal storage.
Disk Usage app: 1.1 GB of 5.5 GB of the internal storage.
You can send or transfer files from PC to your phone up to 768 MB as the phone system should leave some empty space on it.
When you download some apps/files through your phone, there will be a pop up notification tells you that your internal memory limits have reached which the PC can do that.
Best usage for a 5.5 GB storage is 4 GB or 4.5 GB, and you have reached it already.
17 REPLIES 17
profile.country.RO.title
_alexdon_
Could it be only app data?Maybe facebook,chrome.others?
alexdon
Danial-mach1
Leader
so if they are app data why phone dont calculate them??..also if i clear those apps data the difrence will remain the same
a solution i can find till know is factory reset..but it will return with exact 300 or 400 mg lost space
_alexdon_
If you go to settings-storage,can you clear cache?
alexdon
CarbonoAtom
Get the app Es-File explore. then click view and sort it from most space to the least, also one the left hand side, turn on the hidden files. Delete the file which has the most space, usually it might be like the others have said a cache file. Also,The data of cached files will come as misc files Danial, it is hard to view it on the settings as it only shows your app data and will not specify what actually uses that space.
CarbonoAtom Slightly_smiling_Face
Danial-mach1
Leader
nope..i have no options
also setting>apps>all there is just"storage capability" with no options
Danial-mach1
Leader
@carbonoatom
no avail
i cant find any file that i cant see on pc
also es-explorer tell me i have 1.2gb free just like phone say..but pc say 800mg
_alexdon_
There could be an issue with the files the PC sees and the phone sees.So in settings-storage,you do not have cached files?
alexdon
3xperia
Hi, Danial. 400mg? What's an MG? Do you mean MB?
Perhaps the PC reads/writes it different because of the phone chace. Have you tried some app named Disk Usage for Android yet?
Danial-mach1
Leader
@alexdon
yes i found cached data..its 183mb
if i perform factory reset at the starat i have 5.2gb free space..but after time phone and pc goes in to 400mb diffrent
@3xperia
yes i mean mb
what that app will do?
