- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
So, my phone Xperia Tipo has been locked by 20 incorrect pattern entries and I don't remember the answer to my security question. The phone hasn't been tweaked, it's as delivered.
I can't get it to connect with PC companion, because the phone has to be unlocked in order to be accessed. How can I reset it completely?
Thanks!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
You may need to perform a software repair using PC companion.The process will erase all internal memory.You might need to charge your device for about 1-2 hours before so the device has at least 60% battery.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
It worked, thank you!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Great.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Thanks man it s working
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Thanks!
