Hi all
I got an Xperia S in Hong Kong, and I can't seem to switch to Spanish keyboard for writing. I already went into settings to add Spanish as a writing language. But the phone came with the Xperia keyboard, Xperia Chinese keyboard and Xperia Japanese keyboard and seems to default to the Chinese keyboard when writing which only allows toggling between English and Chinese. I want to be able to switch between English, Spanish and Chinese ... any ideas?
Thanks!
do you have ICS or GB?
on ICS
open the messaging app > a converstaion > once you see the keyboard > drag down the notification bar > tap on select input method > configure input methods > xperia keyboard > languages > writing languages > check spanish and uncheck the other options
the steps are similar on GB
open the messagign app > open a conversation > tap on the input box > once you see the keyboard tap on the wrench at the botton > select input language
thanks uliwooly, but that only lets me toggle between English and Chinese ...
and when i try to get into settings by long pressing the wrench, it brings up the Xperia Chinese keyboard settings ...
not quite, you have to uncheck English and chinese and select spanish
sorted, sorted!! thank you ...
long press the text input area to bring up input method!
on ICS
still on GB
problem solved, can now input using Spanish keyboard. THANK YOU!!
if you don't want to wait for ICS
How to manually update 2012 Xperias to android 4.0.4 build number 6.1.A.0.452
http://talk.sonymobile.com/thread/41609
i'm VERY new to the android world (as you can tell since i can't even figure out how to change an input language!) ... i wouldn't know the difference yet between gingerbread and ics
no doubt i will need your help here as i navigate my way through this brave new world! thanks in advance, haha.
check that thread and watch the videos
