ICS: Network Drops, Refuses to Reconnect
thekaz
Hello. I previously posted when I had Gingerbread about a problem I had with the network. It drops (especially when I'm sleeping) and it refuses to reconnect unless I restart the phone. I was given advice that with an upgrade to ICS, the problem would be rectified. http://talk.sonymobile.com/thread/51316
But, even with an upgrade to ICS (Build # 6.1.B.0.544), I'm still having the same problem. Now, instead of my phone losing connection but showing full signal strength, my phone just loses connection and says I have absolutely no signal. With a restart, my phone is fixed.
When I had GB, I tried "reset to factory settings" AND "software repair" through the computer. But, I still had the same problem.
Any help would be very much appreciated. I'm getting very frustrated! Does anyone else have the same problem?
15 REPLIES 15
thekaz
Thanks!!!! I'll do that. I hope it's just some messed up APN settings. I'll play around with it to see if it has anything to do with it. Thanks again!
anytime, don't listen to AT&T
thekaz
OK great. I tried maybe around 5 or 6 different APN settings that I found all over the internet for AT&T's network, including the one that was posted here, to try to get my phone to work. I finally found the exact APN settings that haven't led to a disconnect yet! It looks like the only difference is in what the "APN Type" says!
Thanks to everyone who offered help... really appreciate it!!
For anyone on AT&T using an Xperia, I'd recommend these found here: http://forum.xda-developers.com/showpost.php?p=27982934&postcount=2
Phone
APN: phone
Proxy:
Port:
Username:
Password:
Server:
MMSC:
MMS Proxy:
MMS Port:
MCC: 310
MNC: 410
Authentication type:
APN type: default
ATT
APN: wap.cingular
Proxy: wireless.cingular.com
Port: 80
Username:
Password:
Server:
MMSC: http://mmsc.cingular.com
MMS Proxy: wireless.cingular.com
MMS Port: 80
MCC: 310
MNC: 410
APN type: mms
thekaz
Nevermind. Network and data disconnects after extended standby period and won't reconnect... better than before but every morning I have to restart. Ugh!
Johan
Unfortunately I think this needs to be examined at an repair center to be fixed. Contact your local support team for more information.
thekaz
Thanks, Johan. Actually, I went in and changed my SIM card again and it looks like it's working. Even though AT&T gave me a brand new SIM card only 2 months ago, it may have been faulty. It works now, so thankfully it was my SIM card and not the phone itself.
