I just updated my WT19i just an hour ago, and then i tried to capture a screenshot by pressing power buttong and volume key down at the same time. but it doesnt work. any help or suggestion?
Hi, this should work on the Live With Walkman running on ICS.
Please make sure you are holding down both keys at the same time until you feel the handset vibrate.
What do you think about this forum? Let us know by doing this short survey
press Volume and power button
it doesnt work.
Presss the power button and the Down Volume button at the same time & u'll have the screenshot...:smileyhappy:
Hope It Helps!!
thats what i did, but i cant still take screen shot. i dont know why, i thinks its a bug. btw, is your phone also WT19i?
Presss the power button and the Down Volume button at the same time & u'll have the screenshot.......its work 100%
i only did press them at the same time, but didnt hold them. thanks anyway :smileygrin:
I was also not getting it.. bt finally I found out that u dont have to press n hold power + vol dwn for secs... quickly press them together.. n u will get a screenshot.. keep trying.. once u do it.. u will get used to it
uhooooooooooooo i fund it:smileyhappy:
press Power key and home key at the some time(in android 4)
its work 1000%
Enjoy it
test it in galaxy s2
