How to root sony live with walkman version 4.0.4 bulid number 4.1.B.0.431 ? please help me ? and i want to use cyanogenmod 9 rc1 to my device how can i root rom manger to my phone ? http://www.xda-developers.com/android/cyanogenmod-9-rc1-for-37-devices/
did you checked this?
click on rooting
http://talk.sonymobile.com/thread/38251
click on rooting
http://forum.xda-developers.com/showthread.php?t=1695514
Since rooting directly in 4.0.4 is not possible, one needs to downgrade to a rootable GB ROM to root. (Skip this step if you are already in GB).
To Downgrade, you need to flash an old GB ROM ftf to your device.
i have to downgrade my phone from ics to gb ?
there are myriad way to root
http://forum.xda-developers.com/showthread.php?t=1683189
WT19i_4.1.B.0.431_Generic is this already rooted for lww
should i have to unlock my bootloader for rooting ?
hey how i know my phone is rooted... now my trackid not working ? can i again relocked my phone whenever i want ? please help me ?
if you unlocked your bootloader your DRM files are gone forever, there isn't a way to restore them at all. why did you rooted your phone again? if you had an app in mind try it to find out if you are rooted or not.
using root checker app which i downloaded from play store i checked my root.. showing no access to root. this mean yet my phone is not rooted. i rooted my phone by following instructions suggested by sony itself:
First, you should confirm that it is possible to unlock the boot loader of your phone by checking the service menu. In your phone, open the dialler and enter *#*#7378423#*#* to access the service menu. In your phone, tap Service info > Configuration > Rooting Status. If Bootloader unlock allowed says Yes, then you can continue with the next step. If it says No, or if the status is missing, your device cannot be unlocked. On your computer, click Continue at the bottom of this page to start the unlock boot loader process. Read through the information in the pop up window and click Yes, I’m sure, if you are still confident you want to unlock the boot loader. Read through and accept the legal terms. Click I Accept. Enter your name, email address and the first 14 digits (remove the last digit) of your phone’s IMEI number. Click Submit. You can view the IMEI number by entering *#06# on your phone. The unlock boot loader key is displayed. Write it down and save it for later use. Download and install the latest Android SDK from developer.android.com. Download and unzip this file. This is the standard android_winusb.inf-file, with a few lines of code added to enable Fastboot to support Sony and Sony Ericsson devices. Make sure you are running Google USB Driver package revision 4 or higher in your Android SDK. You can see current Google USB Driver package revision in the SDK Manager. Place the unzipped file in the usb_driver folder, located in the Android SDK > extras > google folder on your computer. Accept to replace the old android_winusb.inf-file with the new file. If you can't find the usb_driver folder, please install the Google USB Driver Packager using the Android SDK manager. Turn off your phone. On your phone, push and hold the unlock button* at the same time as you connect the phone to the computer with a USB-cable. The unlock button may differ between different phone models. See the note in the bottom of this page for more information on what button use on your phone. On your computer, you will be asked for drivers. Point to the usb_driver folder where you placed the android_winusb.inf-file, and select the Android Boot loader Interface-file. Open a command window and go to the tools folder within the Android SDK folder. Enter fastboot.exe -i 0x0fce getvar version, and verify that you get a response back (for example "0.3"). This means your phone is connected properly.
Promotion
About
Warning! If you perform this step, you will unlock the boot loader. This may void your warranty and/or any warranty from your operator. If you still want to unlock the boot loader of your phone, enter fastboot.exe -i 0x0fce oem unlock 0xKEY, where KEY is the unlock boot loader key you got in the beginning of this instruction. The boot loader should now be successfully unlocked.
after doing this steps with my phone now track id not working... i am confused my taking my phone whether my phone is rooted or not ? please help me dude and i want to use some custom roms which is good for my lww
