How to Make Screenshots on Xperia Minipro?
i don't know how to make screenshots on Xperia Minipro (SK17i) with ICS,
when i use gingerbread i can make screenshots with shutdown key then tap take screenshot.
someone know how ?
profile.country.PH.title
MarlonUk1
Power button and volume down key press at the same time
10 REPLIES 10
MarlonUk1
Glorifyday
This doesn't seem to work for ST15i... am I doing anything wrong?
MarlonUk1
it may take awhile, try holding the keys 1-3 seconds, remember to press at the same time
Glorifyday
Yes, it works!
You're perfectly right, I was pressing for too short a period of time ;-).
Thanks a lot :smileycool:.
MarlonUk1
No problem Slightly_smiling_Face
pipepinto
i have the same problem, but in my case it doesn't work. i try and try but it doesn't take a screenshot.
i install screenshot ultimate and it say that "it seen like no screenshot method has been set."
¿how can i set this screenshot method to my xperia minipro ?
makica
thank you! :-
makica
I kept an old version of androind for a very long time, and, I tried a new ond, and, I was disapointed when I realise that old button for screanshoots dissapeared.
I have never been at this forum, I am glad that all of you, gues, are here, and, I can learn much new things.
Specialy thanks for you, norlamlb. 😄
ManojSir
I've read all the above solutions provided for Screen Shot for Xperia SK17i but it's not working.......?????
