How to get into Clockworkmod without an operating system?
We have a big Problem with our Xperia Play R800i! Our operating system has been deleted and we don´t know how to get into Clockworkmod Recovery System without an Operating System. In two weeks we are going to Hungary and we would like to use the mobile phone there so we´d like to use the guarantee to repair the phone but it would take too long. So we hope that you describe us how too get our system back or get into CWM!!!
All the best
FERNman
Nabeel
Update/Repair your phone via PCC OR SUS
SUS ( Sony Update Service)  ... download and install it on pc and follow the on-screen instructions http://www-support-downloads.sonymobile.com/Software%20Downloads/Update_Service_Setup-2.11.12.5.exe
                  or
Both the links are same
11 REPLIES 11
Nabeel
Did you successfully install CWM on your phone and back up your system ?
if yes then -
start your mobile > whenever led notification light turns blue> press menu button one time
Slightly_smiling_Face
Yes I have already installed CWM but I didn`t back up my system because my friend has gone into CWM and sometimes he is a bit too fast! And when i start the phone, the LED´s never turn blue or to any other colour! Only when i connect my phone to the computer the lights turn green. I don´t know what to do!
pls help me!
FERNman
PS: He has gone into CWM by an app.
Nabeel
Is your mobile rooted ?
No it isn`t!
Nabeel
Ooops, thats the reason.
CWM cannot be installed on your mobile until you root, then how come you installed it ??
Downloading from market and installing on your mobile doesn't installs it actually
you need to open that app and then install it
so did you do this way ???
Yes right i downloaded this app then I pressed "install CWM" and then I have booted into it
Nabeel
CWM cannot be installed correctly if you haven't root your mobile
check the screnshot-  Root Available
So the thing is if you didn't root and install it, means it has not been installed
so tellme one thing, is your mobile dead ?? are you not able to restart it ?
i can start the phone but only to the font "Sony Ericsson"! Then it doesn´t do any thing more.
Nabeel
                  or
