How to copy text?
morris108
How to copy text?
In a text editing program, I can select some text and a little box appears above the selection with an option to copy.
I frequently have an email (Gmail) and I wish to copy some text and paste it elsewhere, into skype for example...
But whenever I select the text, the box does not appear above, I have no way to copy what I have selected.
By random chance I have occasionally seen "Text copied to clipboard" appear.
I am sure it is all very simple - if someone could please explain.
morris108
I worked it out!
Actually not necessary to go to forward or reply.
Long pressing will select the text.
A quick tap will copy it - THAT IS THE KEY!
4 REPLIES 4
morris108
I worked it out!
I thought, you were known and tried it, but still it wasn'r working.. thats why i advised you to go in Forward and Reply mode..
anyway problem solved... thats what we want..
Cheers.
morris108
And thanks for helping!
Anytime.
