In the forum says that GB can't connecto to AD-Hoc but here: http://talk.sonymobile.com/message/138549#138549 says that ICS can.
But I just try to connect using an Ad-Hoc that I created with my laptop but my Xperia Pro didn't show me that hot spot.
How can I connect to an Ad-Hoc net?
I think the user was misguided or talking about another feature.
ad hoc is still not supported.
but if you want to share your laptop/pc internet connection to your Xperia, you can try Connectify or Virtual wifi Router. you must be running win7 to use those.
if your phone is rooted, you can look for the app called reverse tethering.
Thanks!!! I will try the Virtual Wifi Router thingy
Cheers! :smileygrin: and thank you again
sure
