How do I know the temperature of my phone?
I know there is a code that indicates the temperature... code like this * # * # 7594 # * # * (this code off the phone).
Google translator.
I know that code as you can see here
http://talk.sonymobile.com/thread/24534
there are many apps but for the most part they will drain your battery, it's easier to use service menu, save the number on your phonelist and when you want to check it just long press on it and tap on edit, it will open service menu
http://www.engadget.com/2012/06/18/android-wakelock-api-bugs/
Android apps that use power control APIs are often 'battery killers,' oh the irony
http://www.tgdaily.com/mobility-features/64061-api-glitch-may-explain-fast-draining-phone-batteries
http://www.purdue.edu/newsroom/research/2012/120613HuSmart
there are other non-battery apps, but they require a LOT of permisions, which it doesn't sound right, why would a temperature app needs to access your sms or phonebook or gps location.
5 REPLIES 5
are you asking or just point it out? you can download a temperature app
Estoy preguntando. Cual app me recomiendan? No conoces el codigo?
Google Traductor
I imagine the service code lets you know the temperature of my phone. Thanks uliwooly.
you can use this too
Testing
*#*#4636#*#*
*#*#IINFO#*#*
battery information
