Hi
I got my phone 4 days ago. After having paired the phone with my car, the phone kept asking which program I wanted to start automatic when entering the car (bluetooth-zone). I chose CoPilot navigation, and this works like a charm. When bluetooth is enabled, CoPilot switshes on every time 🙂 Problem is, I do not always want this to happen. Actually, sometimes it is rather inconvinient.
So my question is: Where do I go on the phone to turn this function off? Or change program, for that matter. Anybody knows?
Rgds Johan, Norway
nolramlb is 100% correct
Just go the app and do the settings or simply clear it's data
settings > apps > all > live ware manager > clear data
Liveware App
Thanks a lot! Seems me "problems" are over.
I have not tried the solution yet, as I got a, for me, rather scary warning, like: All data in program will be deleted permanently. This include all files, settings, accounts, database etc...
I tried to look around to see if I could se a list or sometning of what that actually ment, but found none. Also, if I happen to have more functions activated without me knowing that this is the program that does it, how I could turn off one-by-one or something the like. As you will understand, I am on thin ice here..
Edit: Found it - I put the ikon on the dashboard and started the program from there - alas - everything there in front of me :smileyblush:
