Help to get album art to show up!
I need to know why is this happening, some album arts are showed but alot doesn't. I try with mp3tag, medaimonkey and also putting a "folder" named image but I can't make that the cover shows in the audio player.
I Need some help !
camaro322hp
if you're sure your music files are properly tagged with artwork, try this, it worked for me:
go to settings, apps, "all" tab, Media Storage - click "clear data"
reboot phone
give it some time to rebuild the library - mine was rebuilt within a few minutes.
14 REPLIES 14
profile.country.PH.title
MarlonUk1
do they show up when you view the files on computer?
Yes on my PC it's shows perfect ...
MarlonUk1
try to re mount your sd card , and reboot your phone.
No, I tried, doesen't work.
MarlonUk1
did you try to put the album art on the computer or on device itself?
try to clear music player data> settings>apps>manage app> look for music player tap on clear data
I put the art work on my computer.
I try that too, still not showing almost all the cover artwork.
MarlonUk1
hmmm. try adding again the photos,
using this http://teaching.droidsdk.com/?tag=meka-mp3-album-artwork-tool
or try using
Download - Media Go - Sony Network Entertainment
if not try to remove and re-insert your sd card.
I tried with that tool, andone works, but other continue to fail...
I can't use Media Go, don't know why, it says installing and never advance
I will try deleting all the SD or something tomorrow, thanks anyway!
MarlonUk1
you may want to try to repair your phone together with reformating your sd card, that way you make sure you'll have a "clean" installation.,
be sure to backup important files. Slightly_smiling_Face
