hard reset
hard reset
I did a Hard reset for the ray
it kept going for more than an hour, Whatever i do if i shut it down , take battery off all i see is sonyericsson fading in and out
I tried PC repair but it doesn't connect
Help please it's only 3 days old Slightly_frowning_Face !
try SEUS if it doesn't work you should return it
Update Service (SEUS)
http://dl-www.sonyericsson.com/cws/download/1/110/61/1309763183/Update_Service_Setup-2.11.7.13.exe
12 REPLIES 12
btw does the LED turn on when you connect it to your computer?
that fixed my problem Slightly_smiling_Face
everything is reset and working.
Thank you!
Anytime Slightly_smiling_Face
after the fix and restart
I've selected my langauge as english but the default is german.
Now i see everything in english as it should since it's the selected langauge. But for alerts, error's and such i get them in default german langauge.
I've tried Dutch it gave the same resault everything is in text but alerts in german (or default language)
how can i fix this please?
go to settings -> language & keyboard -> english
It is already english
change the language to American English turn off your phone turn it back on and change it to British English and see if that does it,
Hi
Ok that helped to put everything correctly in English
But everytime i restart my phone it asks me to select the langauge again.
Is this normal?
