I have noticed that the GPS in xperia u to be very slow. fix times are too long and position is less accurate. I tried to compare it with my bro 's LG optimus One(p500). We both stood at the same position and started our GPS and then Google maps app. To begin with it xperia u showed an accuracy of 2900 m where as optimus One showed a better (not much but stil.. ) 2500 m. And within 30 seconds his accuracy came to 7 m and my xperia u is still struggling with 2500 m. It Took around 4 minutes to show an accuracy of 50 m.
How come xperia's GPS be so dumb against a cheap phone.
Is this only me or is it the same case with every xperia u.
How can Sony make these terrible GPSs ? Optimus One is inferior in all the specs but is much better travel companion came very handy in our last trip.
Message title was edited by: pradeeprk4
still no news about ICS release date?
somebody psoted that it is releasing at the end of this month!
I can't wait, my GPS became useless with the buggy software, and they neither release software on time, nor reveal the date.
HATE you sony..
It Seems they posted true new. i forget that my phone has GPS feature :smileyhappy:))))
When I'm using google maps and want to see my location, after a minute of waiting it just says "your location is curently unavailable" no matter where I am, It has never found my location, except for once, I had data traffic enabled and after about 15th try if found my position exactly, But when I exited maps, and wanted to use them again it coudn't find me, again it just said location is unavalable. Funny thing is my bro's cheap lg optimus me has no or very little problem finding location, even if data trafic is turned off (when I had data traffic off, it is not possible to find me, I was trying for half an hour and than gave up)
Hello guys, finally got some kind of round about method to make my gps usable, atleast for my problem.
My problem was not with signal reception or signal drops, but it was taking more than half an hour to fix even if lot of satellites were in view with good signal.
here's what I did..
Turn on the gps, and open gps test or gps status app. After two to three mins it shows around 5 satellites with decent signal. then go to options and tap on update agps data. It'll connect to satellites within few seconds(10-15). It sends only a little of data, so no need to worry about data costs(some times I'm not even charged for it). just turn on data just before you update agps data, and turn off again.
If it doesn't show any satellites with signal, reset agps (or clear agps data) and try again. it will work(atleast worked for me).
In a nut shell, I just updated the gps data. I did it previously too, didn't work then. I think updating agps data after having good signal, making the difference. After connecting to satellites, all gps apps will work fine.
anyway, I can use gps now in the hour of need. Instead of half an hour, it takes less than 5 mins.
check these screen shots.
Hey, OSCAR.. GPS is not working even after ICS update. In fact it got worse for me. the above workaround is also not working anymore.
I guess I should have replaced my phone instead of waiting for ICS.
As you mentioned upper, that's how GPS system works. If you have enabled mobile data, GPS is as first asking network servers in the Internet about current position of sattelites - this calls AGPS. After sending/receiving infos (we are talking about 2-5 seconds) GPS shows lot of sattelites (appr. 13) and fix quickly (f.e. max 40 seconds). Now you don't need enabled network connection and when you turn OFF GPS and turn it bak ON, your GPS will fix after 5 seconds. You can try it after 2 hours and GPS would still fix quickly. But when you dramatically change your position with GPS OFF and you turn it ON, you have old AGPS data about sattelites and GPS "problem" is here. So you have to temporary enable network connection, in Settings of mentioned app tap button "Receive AGPS data"
If you have rooted your phone, you can use f.e. Root Browser to see in folder structure file System/etc/gps.conf . This file contains name of server which it contacts for receiving AGPS data
Thanks for the info dude.
But. I already know everything you've mentioned including the last sentence, and I still can't make my gps work.
The fixes seem to be arbitary. sometimes works quick (I'm talking about 3-5- min) and sometimes not at all(depends on my patience)..Recently, It is not fixing even when I'm connected to wifi and standing in open space. I tried clearing AGPS data and updating it many times.
No phone phone I have seen(with AGPS or even GPS) had this problem. They never had a need to update gps data or clear manually. Within half a minute location shows up in maps.by just simply opening maps. I have to mess up with gps everytime I want to use GPS and not sure whether It'll connect at all.
I'm assuming that it's some kind of hardware issue because software updates, repairs don't work. I'm gonna go to service center and ask for replacement. SHolud've done this long back instead of waiting for ICS,
I always have this doubt. Why shoud we root our phone to make gps fixes faster?
Why don;t they preload the correct server data in gps.conf.
Hello guys,
Greetings from Argentina. I have an Xperia U and have the same problem with accuracy and connecting initially. I'm running 2.3.7 B1.564 stock
//EDIT
Flashed to 2.3.7 B3.184 same problem
Flashed to 4.0.4 B1.10. Rebooted, went out the balcony, opened maps and had a 5 sec pin-point. Perfect lock
Hope it helps
Cheers!
MSG edited: Luzßelito
I'd the same problem where my Xperia P was unable to locate GPS satellites. By activating ONLY the 3G (data) connection on has allowed my XP to locate a satellite within two minutes - do not use wifi!!
However, I still believe that there is a software flaw that needs to be fixed!!
I finally found the flaw, that I had all this time.
I rooted my phone and messes up with the gps.conf and tried many modifications to make it work.
Finally found that it is the problem with the AGPS SUPL server.
it is the server that is contacted by phone to get agps data. If that data is downloaded and there is some GPS signal, gps will fix instantly.
Somehow, that server was changed to
SUPL_HOST=supl.google.com
SUPL_PORT=7276
instead of
SUPL_HOST=supl.sonyericsson.com
SUPL_PORT=7275
This caused problems fetting agps data, and only gps was used to fix, which would usually take 12-15 mins.
One more thing that effects the time of fix is the ntp server. Change it to your own country and the gps will fix within 15-30 secs, even on cold start.
There is an app to modify this file easily, if you are feared of messing up with the file.
(agps server setting is located in advanced settings).
To sum up, if you have set up NTP server to your country, and agps server to sonyericsson and have working internet connection(only for downloading AGPS which is negligible in amount), there should be no problem with gps fixes.
(I PMed Oscar-GPS to know about AGPS server details, credits to him)
After applying these settings, I'm now getting fixes within half a minute and accuracy of 4-8m, consistently, and it connects upto 10 satellites,.
