Fail to update with PC Companion
aarhus
I wanted a good, not ridiculously expensive, smartphone to replace my sturdy nonsmartphone. After some research, Xperia mini pro was the winner.
I have not done much with the phone (synced to google, set up some wireless networks, pretty much it).
PC companion: tells me an update is available. I get a page telling me to learn more about android 4.0 before allowing the "Continue" button to be pushed. After reading it, I push the "continue" button, but at the start of step 2 PC companion just goes back to the home screen.
Software update through phone: "You have the latest software and applications from Sony Ericsson. Your phone is up to date!" (android 2.3.4, build 4.0.2.a.0.62)
Any suggestions? (Xperia and android newbie)
it might be your computer, could you borrow a friend's PC?
also restart your PC > press F8 > safe mode > run SUS
http://talk.sonymobile.com/message/244522#244522
7 REPLIES 7
is your SI number on the list?
http://talk.sonymobile.com/message/199353#199353
if it's not then your carrier most likely it's not going to release ICS
here is an alternative
How to manually update 2011 Xperias to android 4.0.4 build number 4.1.B.587 & others
http://talk.sonymobile.com/thread/38251
you should try SUS too
Update Service (SUS)
aarhus
SUS launches, and when the "checking for updates" bar fills up, it just closes?
aarhus
Ummm... "might void your warranty"?? I just bought the phone!
aarhus
Using my home computer was the trick. Apparently the geniuses at work failed to migrate my full administrator rights with the new organizational "improvements" they have been up to.
