Edit Music Info (walkman)
mikejodhan
Hi everyone, i would like the edit music info apk for walkman. Do i need to root/ flash my phone to install it?
:smileywink::smileywink:
Indeed you will have to root your xperia and mod some permissions
http://talk.sonymobile.com/thread/44888
9 REPLIES 9
profile.country.PH.title
MarlonUk1
no, you can do that by downloading third party apps on google play. Slightly_smiling_Face try searching mp3 tags
mikejodhan
yes , i know that, but im talking about when in walkman , if i click the menu key, i see ' edit music info'. Unfortunately it is blocked and i cannot click it.
And how can i get 'senseMe'?
isn't senseme part of MediaGo on the PC? and you can use media go to change music info.
mikejodhan
do you know how to get the 'edit music info' in walkman to work ?
That's quite odd that it's not working, did you sideload the xperia S apk?
mikejodhan
yes i sideloaded the semc music apk, the visualizer and sound enhancments ....
All i need is the edit music info one
I wanted clear bass, but a root is needed Slightly_frowning_Face
MarlonUk1
oh i see. it either not supported on your device or the file you are trying to edit is protected.
mikejodhan
oh ok, thanks for that (Y)
