Greetings SupportTeam,
I am from India. First of all a very thanks to Sony for making such a wonderful device (Xperia U) , although some users are experiencing netwok problem on 6.0.B.3.162 version So my question is that when 6.0.B.3.171 version would be available in India then will I be able to directly upgrade the firmware version from 6.0.B.1.564 to 6.0.B.3.171 or shd I first upgrade to 6.0.B.3.162 and then to 6.0.B.3.171 because now when I connect my device with Sony PC companion it says a new update 6.0.B.3.162 is available. So when 6.0.B.3.171 will be available will it directly flash 6.0.B.3.171 or will it still show 6.0.B.3.162 ????
Please I would really appreciate if anyone from Sony Support or any user update my knowledge on the same.
Thanks,
Manish
PC Companion always installs the latest update available for your phone
So once 6.0.B.3.171 is available for your phone you will be able to upgrade to it directly without any problem
Thanks a lot for the confirmation Nabeel.
Much appreciated!!!!
