I've updated latest bluetooth drivers for Dell E5420
PC companion goes till, Starts Pairing with the codes in phone&PC. Installing major parts of the drivers fails and Companion doesn't approve the connection. Finish: Your phone cannot connect via Bluetooth at the moment
On Windows7-Bluetooth Device-phone-Properties-Services shows that:
**bleep**
ContentShare
Gen.Access&Atribut
SMS/MMS
XperiaLinx
drivers for these has been failed
but.via Windows Explorer Bluetooth- file transfer works.
SP: has FW 12.0.A.2.254
Any hints, please
>To connect a phone using Android like Xperia SP to PC Companion you need to use USB or WiFi.
>Bluetooth will only work for some of our older models like W995.
Thanks, In matter a fact that is stated in the connection part. I just didn't read that - must say that I didn't even thought that this wouldn't work 😞 For me WLan option is out of the question 'cause of VPN connections.
Luckly found a solution.'MyPhoneExplorer'
-Install MPE to PC & Android
-Pair with Windows7 Bluetooth
-Show Bluetooth devices - your phone should be found
-Right click Properties-Services
-You should find line 'Serial port (SPP) 'MyPhoneExplorer' COMx -> Check the box
-You should see message about Com-port installation
Now you are able to select in MPE under Settings-Connection that Com-port and sync works !!!!
To connect a phone using Android like Xperia SP to PC Companion you need to use USB or WiFi. Bluetooth will only work for some of our older models like W995.
Kudos to GeoffH.
His solution worked on my SP.
2013-04-10 07:33 PM
make sure wifi is turned off and stamina mode is off and try again
there are reported issues with wifi and BT.
